repo man wrote:Those are hard numbers, but what about say, the ease of pulling away from a pack of traffic? Passing? Any problems dusting off 5.0's above 100mph? What about handling on on/off-ramps?
The car is fast off the line, and fast at highway speeds, but around town it can be pokey... it'll drop into 1st gear if you're under 20-25 mph and take off, but if you try to hit it going 30-40 mph you won't be that impressed. You'll be in 2nd gear, and 2nd gear redlines around 80-90 mph.
But once you're going 60-70 mph you've got plenty of power. It'll still drop into 2nd gear if you floor it, and after 2nd gear redlines there's still plenty of pull in 3rd gear.
Handling is impeccable as long as you have good tires and the rear shocks are in good shape (rear shocks wear out faster and can make the car very floaty if they're bad). Sway bar is cheap mod to make handling better ($200-300).
Everything about the Q is geared towards highway speeds. Don't expect to impress too many people just running around town.
