Mirror Turn Signal Removal?
All things Altima Coupe.
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
Anyone now how to take out the turn signal in the side mirrors? Search turned no results and couldnt find it in any manuals. Looks like it COULD just be a screwdriver pop but dont want to risk breaking anything if its not.
srwong
Car: 2009 Altima Coupe 3.5 SE CVT
why would you wanna take it out?
ms_coupelover
Car: 2008 Nissan Altima Coupe
only the turn signal? or the whole mirror?
DJ_B_Easy
srwong wrote:why would you wanna take it out?
I want to smoke them when I do round 2 on my tails. Trying to remove all color but black, grey, and the stock dark slate from the exterior.
DJ_B_Easy
ms_coupelover wrote:only the turn signal? or the whole mirror?
Just the signal if possible. Although taking off the mirror could work and then I could just mask the signal, but I definitely dont want to leave 'em on the car and smoke em.
ms_coupelover
when i got mine installed the mirror actually comes apart so just take the color cover apart its easier you dont have to worry about ruining it!
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Tilt the mirror upwards and you'll see the plastic clip of the mirror cover. Take a thin screwdriver and push on the clip and the cover will pop off enough to get you finger behind it. Then gently work the rest of the cover off. Unclip the connector from the signal and remove it. It's that easy! Now Go, Fight, WIN!!!!
Jose3.5
Car: 2007 Nissan Altima SE 3.5
Why dont you just get some vinyl to cover them?
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
Jose3.5 wrote:Why dont you just get some vinyl to cover them?
My thoughts exactly. This is what I did.
DJ_B_Easy
Considered that too, already have the spray though and Im not really a fan of vinyl.
dangeris wrote:Tilt the mirror upwards and you'll see the plastic clip of the mirror cover. Take a thin screwdriver and push on the clip and the cover will pop off enough to get you finger behind it. Then gently work the rest of the cover off. Unclip the connector from the signal and remove it. It's that easy! Now Go, Fight, WIN!!!!
Dangeris I'll take a look at this tomorrow in the daylight, thanks.
DJ_B_Easy
In case anyone was wondering Dangeris' instructions were spot on...but it is a b*tch to get that first clip undone. There are actually three at the top, i popped out the middle one and then worked to the inside one, then outside. A few more along the bottom and thats it! Signal slides right out, its actually held in by the cover for the most part.
Tint is sprayed and drying!
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Glad you were able to get the cover off. The hardest part of taking the cover off was the long clip on the bottom.
For you 2.5's there's only 2 clips that hold on the cover
DJ_B_Easy
dangeris wrote:The hardest part of taking the cover off was the long clip on the bottom.
The one that looks like a fork? I snapped it, haha! Everything still fit back in real snug, ssems like the 3 top and the one side nearest the body holds the most weight.
Finished product! Sooooooooo sex...
srwong
hm looks good. any further back pics? and how about at night? or during day, are the signals still visible?
DJ_B_Easy
srwong wrote:hm looks good. any further back pics? and how about at night? or during day, are the signals still visible?
Im going to get a few more pics this week. I get my new wheels tomorrow so Im going to do a bunch of pics to show all the mods Ive done since Ive been here on NICO, creepin around soaking up all the knowledge. Been about 3 or 4 months so I think Im due.
As for if the signal is visible...night time a little, daytime HELL NO unless you are right up on it. I sprayed 2 coats on because I missed a tiny little bit of the end of one, but I think 1 coat would have had the same effect. I dont really mind, I might try and use my Goof Off to strip and re-spray just 1 even coat in a few months, but Ive had enough of tinting/stripping/re-tinting for a LONG time right now.
Pics to follow of the full Coupe later in the week!
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
DJBeasy wrote:I might try and use my Goof Off to strip and re-spray
Use lacquer thinner to take off the spray tint. You can either take the cover off again or be really super careful that you don't hit the cover.
DJ_B_Easy
Dangeris I actually had a disaster with the tint on my tails the first go 'round. The Goof Off removed 3 coats of tint and 1 coat of clear COMPLETELY with no damage to the plastic housing. I swear by the stuff now...but yes the signals will definitely come OFF the car if I decide to strip them.
Thanks for your help on this.
dieseldom
Car: 2008 Super Black Altima Sedan 2.5SL Fully Loaded
Looks real nice, mna!! :dblthumb:
darrdevil
Car: Oh ten A/C 2.5s
Looks good. Nice job.
