Mirror grinding noise
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
jvangun
Car: 2012 Infiniti QX56
I’ve noticed a weird “grinding” sound when I put my car into reverse and the mirrors auto-tilt. Wondering if there is any type of lubricant I could spray that wouldn’t damage any plastic components. Odd part is it sounds equally as bad from both sides.
Thanks in advance.
marctronixx
is your car under warranty?
take it in and have the dealer deal with it.
if you dont want to do that, i think there is/was a tsb on the mirrors on the 2011+. this site has the tsbs i think but if you can't find them go to x dot infinitihelp dot com and they are listed there.
jvangun
Greatly appreciate the tip @marctronixx. I found the below which looks to potentially be related. My QX is out of warranty but emailed the local dealership today.
Subject: SB 2011-2013 QX56; Door Mirror Clicking Noise - OK
Summary of ITB12070:
SERVICE INFORMATION The "Reverse Tilt-Down" feature will move the glass on the outside mirrors downward when the gear selector is placed in the Reverse (R) position. As the mirror glass moves downward, it may reach the end of its travel. If the mirror g
marctronixx
thats the one i was referring to!
print that sucker out and take it to 'em!
jvangun
Here is what I got back from the local Infiniti dealer:
If the vehicle is out of basic warranty which it appears to be on miles we would need to verify the bulletin matches the issue and put an estimate together for the repair. This may also require some diagnostic up to 130.00. Because it may have an associated TSB does not make it a warranty matter unfortunately. Thank you.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
