Some of you may remember that when I first got the car, the transmission fluid was so bad that it was purple with a pearlescent look to it, and clearly had severe particulate contamination. I was thoroughly convinced I'd be putting a transmission in it soon. I dropped the pan and looked at the filter screen, and thankfully it was clear. I cleaned out the pan and the schmutzed-up magnet, replaced the screen and gasket, and refilled with fresh Dexron III fluid and added the Magnefine. Still pretty dirty, but better. A couple months later I got a flush done at Iffy Lube with Dexron III, and the fluid was better still. 2 months after that the fluid was looking a bit funky again, so I did a BG flush at work with Wolf's Head Universal Synthetic ATF and added the B&M 70268 transmission cooler (around August 2010.)
The fluid has been fine ever since, and I decided to swap out the Magnefine and take a look inside it. I cut it open and looked at the paper media, and it was VERY CLEAN! I was able to blow through the filter prior to opening it, and it had barely more resistance than the new one. I also took a gander at the magnet, and it was nearly spotless. There was just a bit of stuff on it, nothing like the thick layer of fuzz i Cleaned off the pan magnet last August.
The transmission is still shifting great, and I'm hoping it'll last until 300K along with my motor. I plan on switching to Amsoil ATF in the near future to go along with my Amsoil motor oil, which I am very happy with, BTW.
I will say that as far as the Wolf's Head fluid goes, it wouldn't be my first choice, but after using it for a year and seeing the condition of the fluid I am pretty happy with it's performance.
Wish me luck on the 300K goal...
