K03sport »
https://forums.nicoclub.com/k03sport-u129071.html
Sun Aug 02, 2009 5:14 pm
adjusting hte belts is easy
Engine off:
1. First, remove the cover (splash guard) under the front of the engine
2. Next, loosen the nut on the pulley with the loose belt...DO NOT remove the nut. This step must be done before trying to move the pulley up or down.
3. Find the bolt (hex head) that goes to the tensioner pulley and give it a 1/2 or full turn
4. Now, tighten the nut on the pulley (24-28ft-lbs)
It is easiest to do all adjustmetns from underneath the car.
Start car. If still squeaking, either you need to tighten the belt more or you adjusted the wrong belt. repeat steps above. At most, a few turns should be enough. Without a proper belt tension measurement tool, it can be difficult to know how tight your belt is.
