atlM35 wrote:You can try taking it up to 60mph and slam on the brakes until you're just shy of coming to a complete stop... like when you're bedding in new brakes.
Repeat 3 times and drive around to let it cool down.
Yes, indeed! The above is a good thing to do with new pads and/or rotors too - it is part of the normal installation procedure, and I would do it more than 3 times too.
I agree with you on the "just shy of coming to a complete stop" ... the Infiniti procedures recommend a complete stop, and they are wrong! Rather than lining the rotor surface with a thin amount of pad material, resting a pad for a few seconds on a very hot rotor can deposit a clump of pad material right there! Sometimes you can even see the outline of the pad on the rotor.
Then this clump of deposited pad material can cause vibration when braking, and is then best removed with a resurface of the rotor - which is a waste for a new rotor or pad.
Z
