minor parts question/request
redamnavit
Hi all, I'm trying to source a few minor parts for my clip and I can't figure out either what to ask for at the parts desk or which US model car to ask for it from.
1) I believe this is the FICD? I don't know if I'll need to replace just the grey plug or if it'd be better to replace the plug and the solenoid thing itself.http://home.comcast.net/~redamnavit/ficd.jpg
2) I'm also missing one of the bolts from a bracket, and two from the valve cover...http://home.comcast.net/~redam...s.jpg
If anyone has any spares of these hanging around, or could tell me what bolt to use or car to order the FICD from, I'd appreciate it.
Thanks.
Jezz_s13
Car: Sil80 Track Car
if you don't have AirCon you don't need the FICD, it raises idle revs for when the A/C is on, all CA's had it fitted regardless of whether the car had AC.
The bottom timing cover bolt is std M6 ~ 20mm long, the other is for a cable clip which is M5 ~ 10-15mm long but if you don't have the clip then I wouldn't worry.
Not sure about the PAS pump one, probably M8.
redamnavit
[QUOTE]Originally posted by Jezz_s13 "]if you don't have AirCon you don't need the FICD, it raises idle revs for when the A/C is on, all CA's had it fitted regardless of whether the car had AC.
I do intend to keep AC so I'll still need to source one of those. I appreciate all the bolt sizes; beats hunting down ones off of other engines.
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
man just when I was gonna post I saw this, I need the same thing here's the pic of mine, I guessing we can find one off a pulsar?
NeedCAforS13
Car: CA swapped S13 coupe
yeah, pulsar ones work fine... mine was broken too! granted I don't have A/C to test whether it works or not, the Pulsar one looked identical and attached fine:)
Sean
float_6969
Mine was broken too, but they sent me a new one. I may actually have an extra. I'll check tomorrow.
Doogz
Car: '89 240sx coupe
Mine was snapped off, and since its not that important........JB weld!
redamnavit
anumeric wrote:man just when I was gonna post I saw this, I need the same thing here's the pic of mine, I guessing we can find one off a pulsar?
anumeric, where in VA are you located? I'm going to try to hit up the local salvage yards in the next couple weeks; I'll see if I can find more than one of these things. Considering how ours broke identically it must be a fairly common casualty during shipping.
anumeric
I live in virginia beach, if you could that would be great!! I will be hitting up some local junkyards as well. and I will keep an eye out for you as well.
wei
