dustovshio »
https://forums.nicoclub.com/dustovshio-u55331.html
Mon Jan 18, 2010 4:13 pm
Removing the square part by filing won't give you more hp because the throttle is fully engaged at the point where it touches the square peg. If you have the TT model on the other hand you will see that the throttle doesn't go all the way to the peg, and instead shops a couple mm short. This is because there is a small bolt that prevents it from touching the peg, you can take it off using a 10 or 12 mm socket ( one or the other). I believe the writeup mod was intended to address this issue, though it isn't very descriptive. Hope this helps.
