Minor fuel leak
N!SMO SILVIA
Car: 95 240sx
so my 95 240 has a minor fuel leak. The leak is coming from the fuel tank and im not sure if its driveable. Does anyone know if the car is driveable like that? Does anyone know how i can fix the problem?
supra brit
Car: '93 Supra, '94 240sx 'vert
Yes you can drive it like that, you'll just waste gas, but it's not the best thing to do. I would just fix the problem. Most likely it's just one of the lines/hoses, change out the hoses and clamps and you should be fine, unless you live in the north and have rust issues...
Edit: Now I see your in CA. Prob. just a line then.
