Minor details
mikeh16
Car: s12 200sx
I am almost done with the swap. I switched out my CA dump pipe for an SR dump pipe and downpipe. I have the oxygen sensor screwed into the bung on the top of the dump pipe, but there is another bung further down. I am really having trouble finding a bolt that will thread in the hole. Is this leak going to hinder performance or damage anything? I wouldn't worry about it so much, but it's right next to the turbo. If I can't find a bolt I guess I'll have somebody weld in a slightly smaller bolt to cover the hole. Just wanted to know what my best course of action is.
Thanks,Mike
RMiller
Car: BBQing
mikeh16
Car: s12 200sx
Maybe I'll get that, but do you know for sure that it will fit the hole? Also, the bun that I'm trying to plug up doesn't have the little screw-in adapter because it's in the other hole with the sensor. Does anybody know how big that opening is or if that fitting is designed for that opening?
Thanks,Mike
slw240sx
Car: 1990 Ca18det 240sx Hatch
hammer a knickel down into it! its roughly the same size i would put 2 in there, yes im talkign about the coins.
mikeh16
Car: s12 200sx
Really? Has anyone else done this?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
i dont really know how safe that would be.... sounds like jon speaks from experience though.
that plug is for some stupid emissions junk that the SR had. look for a "AIV" plug. it can be found at http://www.heavythrottle.com under "custom products" (4 from the bottom, left margin of page) for a rediculous $12.00 plus shipping.
- tim
nocwage
Is it not a standard thread?I can't imagine you wouldn't be able to find a bolt that would fit that hole, most likely it's metric threading.take the piece into home depot, it the metric section and go nuts till one fits.
nocwage
K n freshalloy someone claims it's M24 x 1.5So it's same diameter as the O2 sensor but finer threadpitchSo goto some home supply store and get one for $0.25 instead of $12.00 + shipping
float_6969
Yea, just take that baby down to your local hardware store and start checking bolts out till you find one that fits. Make sure and put some hight temp loc-tight or a lock-washer on there so it won't vibrate back out.
mikeh16
Car: s12 200sx
I tried one hardware store, and no luck. Okay so just to clear some things up, there is the thing that the oxygen sensor screws into, then that thing screws into the dump pipe. I need a boly that screws into the dump pipe not the sensor threading. Anymore help?
r34 gtr
if its a stock sr o2 sensor housing, it should have 2 bungs on it, one for the oxygen sensor and one for some aiv thingy. look in the picture on heavy throttle. im talking about the nut thingy in their picture.
- tim
biosehnsucht
Maybe it's the same size as the KA's AIV and EGR holes, if so you can try getting part 14052-21R00 from the dealer, it should be very cheap. Courtesy Nissan actually had them in stock when I picked them up for my KA.. they're OEM plugs because they're used on the Frontier or something, but you can use it to block off the exhaust side of the EGR/AIV on KA's, probably same size for SR.
float_6969
mikeh16 wrote:I tried one hardware store, and no luck. Okay so just to clear some things up, there is the thing that the oxygen sensor screws into, then that thing screws into the dump pipe. I need a boly that screws into the dump pipe not the sensor threading. Anymore help?
OK, just so we're all on the same page here...
The Turbo housing connects to the O2 Pipe, the O2 Pipe connects to the Dump Pipe, the Dump Pipe connects to the Test Pipe, the Test Pipe connects to the Cat-Back.
Do you want a plug for the O2 Pipe, or the Dump Pipe?
biosehnsucht
float_6969 wrote:The Turbo housing connects to the O2 Pipe, the O2 Pipe connects to the Dump Pipe, the Dump Pipe connects to the Test Pipe, the Test Pipe connects to the Cat-Back.
o/ The Turbo bone's connected to the, O2 boneThe O2 bone's connected to the, Dump boneThe Dump bone's connected to the, Test boneThe Test bone's connected to the Catback bone.. o/
WeldingHank
Car: 1989 240sx CA18DET
take the AIV fitting out of your stock KA exhaust. hack off the pipe from it. drop a nickel in the Dump tube hole, put the KA AIV fitting on top of it REALLY tight. your done.
