Minnesota Help wanted. engine install
KoupeDaVille
Car: '90 S13 Coupe, '99 Q45
Anyone know of a good place in MN TwinCities area to get an engine installed and how much it would cost just an estimate. 89 240sx 5spd.Thanks Koupe.
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
I live in the country by Faribault MN I could do it for email me at [email protected]
KoupeDaVille
e-mailed you.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
uh... my house? or propulsion, or John Haley motorsports
me or phil (gt2510s) could do it, but i live in brooklyn park, so i imagine i'm closer than he is, and by imagine i mean know....
BP is about 15 miles from minneapolis, and i just happen to have an open engine stall right now.
if we are just putting in an engine, and i dont know if you mean we or just me, but it should take us 2 days MAX, most likely around 4 to 8 hours depending on what we are doing. ive never done a SOHC swap, but a gang of DOHCs, so it might take me 8 hours or so
couple hundred bucks sounds fair, shoot me and e-mail, and phil i need the money WAY more than you do
s14 2510's
If your doing it for 200 bucks more power to you I dont want to deal with that greasy mess. + He still needs to find a E to swap into it. Have funPs you need help give me a jingle I still need to give you that driveshaft.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
i put the transmission in on last sunday, broke in my XTD stage 3, and now i need to weld that car's diff.... but its a lotta fun...
i'd send him to elk river for an E, but i dont even know if im down with two hundo
KoupeDaVille
Hey thanks for all the help guys, I'll get in contact with you (DjPantsSpecR) when I get every thing together. I actually live in St. Cloud I just put TC because more people know where that is.Thanks again Koupe.
s14 2510's
If you take the diff out I have a specal gell that you spray on the gears so they do not get brittle when you weld the diff. You dont want to get it too hot or you will have a junk diff. The jell takes the heat out of the steel. Its fror welding sheet meal together so it will not warp when you weld it. Give me a holla I can take it to my cousins shop and get r done thats were I did mine. Soon we will have just about the same setup in our s13's. LOL I still have rsr gt2 exhaust to install and a hot shot header on the way. I want a 3" hi flow cat too before I install my exhaust. I know others that want there diffs welded so I will give you a jinge and we can have a diff welding party.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
far out and solid and right on, as for my exhaust set up, i'm making a test pipe cut-out. from summit the manuel cut out is only 46 bones, and a test pipe can be made... plus sometimes you want to be ridiculously loud, other times you want to not kill yourself on the highway...
