240nspec »
https://forums.nicoclub.com/240nspec-u94388.html
Thu Aug 14, 2008 6:10 pm
Have a KaDe, Compression test resulted in 152 psi across cylinders 1,2,4 and 153 on 3. Is there a possible reason for such lower compression across all of these cylinders, or is this nothing to worry about? FSM specs 151 minimal, I doubt all cylinders don't have "leaky" rings, or valves not sealing completely. All fine, or something to be concerned about? Just wondering why minimal compression equally across the board, 140k on the motor. Just wear?
--240nSpec
Also, Engine was at operating temp as well as the TB WOT.
Modified by 240nspec at 9:20 PM 8/14/2008
