Mines tuned ecu...problems
Grambos13
Not really problems but just problem...It worked fine for a month or so then one day the tach just stopped working...I plugged in my stock ecu and the tach wors fine. Any suggestions as of what I should do?
240sxed
sometimes a wire/screw gets loose, try replugging it in. See if you're recieving voltage on the pinout corresponding to tach.
Grambos13 wrote:Not really problems but just problem...It worked fine for a month or so then one day the tach just stopped working...I plugged in my stock ecu and the tach wors fine. Any suggestions as of what I should do?
Grambos13
Ok...I will try that once I get my engine back in...She's out for a rebuild at the moment.
Grambos13
nope...still not working. I took the cover off and cant see any evdience of burning...
