S13FASTBACKSR wrote:what are going to be your mods when you have your ecu reflashed for the first time? bigger injectors, turbo? ive talked to chris and scott at enthalpy numerous times..things that need to be tuned for are more fuel than and more air..if you put bigger injectors on you are going to have to have it retuned..say you have a t25 and you go to a t28 you wont need to have it tuned for that..but anything bigger than a t28 i would recommend a tune..a bigger maf, fuel pump..those need to be tuned for..bigger cams as well..but when you go and put things on like a flywheel or fpr or pulleys you dont have to keep getting it retuned..basically if you just get a setup that you will be happy with the first time and have a tune for that...you will be set..and once you are a customer of enthalpy another reflash is only 125 bucks
Once my engine upgrades begin, it will start with injectors, maf (if i dont already get it by then), and turbo and supporting mods (looking at 2871 i believe, cant remember off the top of my head) for the first upgrade. After that will be cams (along with head gasket), then probably work on the lifters. So that would be 2 different tunings.
I don't want to get ahead of myself, I was just looking at the Mines setup and wanted to know a little more about it. I like being able to tinker with stuff too, especially when I start to learn more about the car/engine. Since I have no set time line for when I will be doing upgrades (unless they deploy me and I make all that mad tax free cash) I'm sure new techniques will be developed and new electronics will come out (or not if the market moves else where and support for the 240/SR20det drops off).
Thank you for helping me understand the whole tuning thing a little more. It does make more sense to me now. Just curious though, you said with the fuel pump and injectors you have to get it tuned, it this because of the injectors? I got the walboro pump, is there complications with using this pump and not tuning the ECU to utilize this? Or am I just reading too far into it?
