Mines computer 550's z32
spotteddawg
have a mines computer programed for 550's z32 t-28 ,bought from alex props man thanks,have a safc2 in the car now,but would like to keep it for rpm and knock readings.So the question is can I keep it hooked up and if so do i change anything on the controller?like set everything back to 0% or change the sensor setting?or should it be ripped out?any help would be great.thanks guysspotteddawg
S13240
Leave it connected for fine tuning.
ckamc
especially when those ecu's are mode for higher than 91 octane
spotteddawg
thanks guys for the info.but would i need to take the maf wire coming from the safc2 ,out of the loop or leave it and set the safc2 on a different setting?thanks spotteddawg
spotteddawg
well after trying a few settings I found putting the SAFC2 sensor setting to 0/in and 0/out the car idled normally chaging any one of them would cause the car to idle but not rev over 3000rpm.So with an ECU tuned for a z32 ..sensor type would be HOTWIRE>0/IN and 0/OUT
