I could use some help with a code P0171 "system lean bank 1" on wife's '01 Pathy with 80,000 mi. Fuel-Premium I'm trying to avoid the black hole (in my wallet) of parts swapping as so many of my colleagues have unfortunately entered before me, and from the wide spectrum of fixes leading to a successful outcomes i.e. zero code, this code fits no clearly defined set of causes.That said, Here's what I'm working from:
Vehicle idles/runs excellent except for some detonation under moderate load. No hill = no pinging. Checked for air leaks and found none. Cleaned MAF despite the logic that says BOTH banks should set codes but heard from Nissan tech claiming to have seen these go bad and only set a code on one side-anything to confuse me. Immediately upon start up, the code for opposite side-0174 "too lean Bank 2"- set, took a 35 mile trip with wife on interstate with plenty of uphill grades and voila-zero codes.
Fuel trims over three cycles are as follows:
Short term fuel trim Bank 1 was unchanged over three cycles at 1.6%. Long term Bank 1 also unchanged but @ 32.8%. Short term Bank 2 averaged (-) 2.6%, and Long term Bank 2 averaged 31.5%. However, following the MAF cleaning and the temporary switching of the codes (171 to 174 then back), and the "clean" 35 mile drive, the trims changed substantially: Short term Bank 1 went to 6.3%, Long term Bank 1 went to 31.3%, Short term Bank 2 went way up to 3.9%, and Long term Bank 2 dropped to 28.9%.
Could the variance in trim indicate a bad MAF? One other thing I forgot to mention is the presence of "rotten egg" odor that always accompanies the detonation when climbing. My thinking at this point---Since the pinging is a lean condition and in itself would not cause the sulphur odor, could the MAF malfunction to the point of creating a "lean" condition which in turn is causing the pinging and then try to adjust for this condition by dumping excessive fuel back into the cylinders and as such causing the rotten egg smell of an over-rich condition? Bad MAF? Seems like a reach but...
This one's working my mind overtime. I'd be grateful for any help out there. Thanks.
homily.
