Milling the head
toki
Rarg. We need a fuel technition here or something. I need to know what levels if any of Toluene/Xylene are safe to run for daily driving for an extended period of time...
Unnatural
1 part Xylene/Toulene for every 3 parts gasoline will work fine. Just remember to add Marvel Mystery Oil to the mix. The oil will prevent all the fuel systems rubber components from drying out and keep everything well lubed. This is the exact mix I used to use, as I stated above, with no drama. With 91 octane this mix works out to be about 97 octane and is only 25% Xylene/Toulene, which is still within the 30% safety limit.~Brendan
toki
heh how much oil to be exact? Sorry to keep bothering, but I dont want to add too much or something and have a tank full of black puff gas, or too little and a damaged fuel system. Thanks for the help :D
Unnatural
I believe I added half a bottle of Marvel Mystery oil to the tank but it's been a bit over 2 years so I'm not positive. Oil burns a light bluish color :D
