TheOne »
https://forums.nicoclub.com/theone-u18820.html
Mon Mar 12, 2007 8:07 am
FSM states standard disortion is 0.0012in, limit(surface shaving) is 0.004in
if your mechanic does shave it(which looks to be safe limit, wouldn't shave it again if something happens, this is knowing that the block hasn't been milled too, as that changes the limit), if you want to be on the safe side though, buy a thicker headgasket.
also when the engine is fully assembled, rotate it a couple of itmes to be sure the valves aren't hitting the pistons.
