420sxse »
https://forums.nicoclub.com/420sxse-u27656.html
Wed Mar 08, 2006 12:27 pm
So, according to my '92 DOHC manual 0.014 in. is almost double the maximum. Maybe the difference in cams lets the newer ones get away with that? I don't know. If you have .014 in. milled off, subtract that from the warpage amount. Then subtract the allowable warpage from the remaining amount. If it's still greater than zero, you have too much to correct. I highly doubt the max allowable warpage for yours is different than mine (0.004 in)If the machinist is right about the 0.014 in figure: 0.018-0.014=.004 0.004-0.004=0. I wouldn't do it though.
Modified by 420sxse at 2:47 PM 3/8/2006
