mileage to change water pump
Tdiazsch
Car: 4wheels. a turbo, and a bamf
i dont think my water pump will be going out to soon but my sr has about ~~40k on it but i was wondering when would be a good time to change the water pump on it just for safety reasons...
this will help a drunk bon fire convvo..thanks !! =]
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
If its leaking change it, If you just bought the swap change it now. Regardless of the mileage just so you know when it was done last. Change the thermostat while you are at it.
Make sure to let the RTV cure for a long time.
Tdiazsch
would you say about 4 hours?
OM3GA
I let mine cure over night but im insane.
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
RTV will tell you how long it needs to cure. It'll be fine after a couple hours, but check to make sure with your application.
You change the water pump when it fails. If the motor is out, change it.
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
OM3GA wrote:I let mine cure over night but im insane.
I do too except I try to give it a full 24 hours not just overnight.
OM3GA
yeah mines been curing for about 4 months now. LOL Damnit i still need to make my build thread.
codyace
Car: S14 w/redtop
As said above, unless it's leaking, leave it alone. Job should not take more than 30 minutes, with the longest part being removal of the fan assembly if still using the OE fan.
In regard to the sillicone cure time, the prefered Ultray Gray Sillcone should be ok/dry in one hour, but suggets 24 hour wait time for full hardness. I'd say wait 4 hours and you should be ok.
