Mileage Poll - How many miles on your Rogue?
Rogue Mileage Poll
0-40k miles
15
58%
40-60k miles
3
12%
60-80k miles
4
15%
80-100k miles
3
12%
100-120k miles
0
No votes
120-140k miles
0
No votes
140-160k miles
0
No votes
160-180k miles
0
No votes
180k-200k miles
0
No votes
200k and over
1
4%
Total votes: 26
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
If you want please give year, trim (S, SL, etc) and any major mechanical issues or failures you've had. If needed please convert to approximate miles (1km = 0.62 miles). You can come back to this poll and change your vote when needed.
bill875
Car: 2008 Nissan Rogue SL AWD
Indigo Blue
Premium Package / Fully Loaded
2008 Rogue SL AWD bought new, 11/2007. Current odometer reading, ~96,200 miles. Biggest mechanical issue so far: AC compressor failure @ 94,800 miles (July, 2014). Everything else has been routine maintenance (Brakes, Oil, Tires, Coolant, drive train fluids, etc.)
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
2008 Rogue FWD SL, bought new April, 2008. CVT replaced shortly after new, since then the vehicle has been solid, no major mechanical failures but some smaller issues including pre-catalytic converter failure, and intermediate steering shaft worn and replaced. 60,000 miles, original brakes still going, very low maintenance costs, overall a solid average to slightly above average ownership experience.
ristau5741
2011 Rogue SL, 23K miles, bought in May with 19K miles, no problems so far (knock, knock)
morselicious
Car: 2008 Nissan Rogue SL AWD Gothem Gray/350K@sold
2009 Toyota Rav4 /sold
2011 Toyota Rav4/sold
2018 Toyota Rav4/sold
2001 Rav4 AWD /Black/ 130K (present car)
Love my Rogue.I have a 2008 SL AWD. Bought 11/2007. She has on it 212,000 mi. I had the CVT changed at 98,000 mi under warranty. Other problems a/c compress seized at 140,000. And I have had a running problem with the fuel gauge. Looking to replace it with one from a 2012. Other than the regular, brakes, tires, and CVT fluid.
Ferrisfan
Car: 2014 Rogue SL FWD w/ Premium Package
2014 SL with premium package FWD. Purchased new in March. 4000 miles. Only issue has been the NAV system TSB update.
RyleyinSTL
Car: 2014 Nissan Rogue SL AWD w/ Premium Pkg.
2014 SL, purchased 04/2014 - 2500 miles
D-Rock
Car: 2008 Rogue S AWD
2009 Rogue S AWD
2011 Rogue S AWD
2014 Rogue S AWD
2014 S AWD purchased 04/2014 35,000km.
phmichel
morselicious wrote:Love my Rogue.I have a 2008 SL AWD. Bought 11/2007. She has on it 212,000 mi. I had the CVT changed at 98,000 mi under warranty. Other problems a/c compress seized at 140,000. And I have had a running problem with the fuel gauge. Looking to replace it with one from a 2012. Other than the regular, brakes, tires, and CVT fluid.
This is encouraging - thanks for sharing this. When they do a CVT swap do they replace it with a 2nd generation unit?
soccerfan
Car: 2009 Nissan Rogue S
2009 S. Purchased used with 57K on the clock.
CVT failed June 2014 with 108K on the clock, replaced under warranty.
CV boot failed Aug 2014, replaced Seprentine belt in July 2014.
Replaced rear brake pads July 2014, worn completely away.
I'm guessing fronts were done before I bought the vehicle, still
lots of meat there.
Power locks come and go intermittently.
reading about a/c compressors failure scares me a little bit.
phmichel
soccerfan wrote:2009 S. Purchased used with 57K on the clock.
lots of meat there.
Reading about a/c compressors failure scares me a little bit.
I'm on my first Rogue and relatively new to the forum, but it looks like the A/C compressor failures have been primarily the magnetic clutch. Doesn't appear to be too expensive and I've seen several posts that it was a DIY job.
CapeCodChips
Car: '14 Nissan Rogue SV Gun Metal Grey
2014 SV AWD purchased 1/2/2014
28,000 miles
therealroland
Car: 2014 Nissan Rogue SL AWD + Premium Package; tan interior
2014 SL AWD, purchased 3/2014 - 5200 miles
JLD94
Car: 2014 Nissan Rogue S Moonlight White
2014 S, purchased 12/2/13, have 16,700 so far
phmichel
At 32k I just had a transmission seal replaced under warranty. It required the transmission to be completely drained and refilled, so it saved me $400 because I didn't have to pay for it at the 30k service.
When I was under the car changing oil I noticed a little oil on the rear motor mount. Had the dealer service check and they replaced the seal. Just an FYI for you guys - something you might want to check. It's expensive to do out of warranty.
JB'sTitanXD
Car: 2017 Titan XD Cummins
14 Rogue SL - 10k - Purchased Mar 14 - Traded Sep 14
Return to “Rogue Forum”
