KEMP »
https://forums.nicoclub.com/kemp-u119247.html
Fri Feb 05, 2010 7:55 am
i also ave a CA18DET thats fully built, and its almost done, should be around 400-500whp on pump gas.
but i have a KA as a daily, which will eventually be my drift car.
i wanna know what all you gys recomend for a little more power, i know i need to do the 248/248 cams, but other things than that,
current mods are.
NO air filter(dont flame)stock exhausts with test pipe, and no axle-back.timing is up.compression is between 190-200i also have a 6puck stage 3 in it, with a welded diff.AIV/EGR is blocked off, but a bit "ghetto" but it works.
what are some other little things i could do? fyi, its the strongest KA ive ever had, and the strongest ka that anyone around my area has seen.
ive been thinking of boost, but would rather have it NA. just to see what i can do..
