johntom240 »
https://forums.nicoclub.com/johntom240-u160210.html
Mon Oct 10, 2011 7:29 pm
well, dont hate because there is no pics, im sure u can all imagine a grey 1991 s13 with lowering springs. so my goals are to switch to e-85 and have close to 180-190 horses with just bolt-ons , but since my headgasket is going ive decided 2 upgrade. found a head straight from the machine shop, oversized valves, retainers, stainless springs and all its ported also.i got stage 3 cams with it also. if you guys could fill in the blanks on what i will need or will not need im just not sure what will be nessacary. and as far as the bottom end goes.. just piston rings, every seal, freeze plug, gaskets,bearing,pump, etc will be replaced as part of rebuild.
msd blaster ingnition
underdrive pulley
remove butterfly valve in intake mani
short-ram/cold air intake
headers-recomendations plz
(already have 2.25 exhaust straight 2 magnaflow)(no cat)
sr 370cc injectors
upgraded fuel pump( input plz i dont know what i need)
300z fuel filter(already have)
q45/300zx maf
if i am missing anything or if u have any suggestions as far aswhat i should use plz i am all ears
