97 Maxima with 66k miles.
I just did a major tune-up on the car which included:
1. Knock sensor and harness2. NGK plugs (thanks for your help NICO)3. Synethic engine oil, mobil 1 filter, synethic brake, PS and transmission oil.4. Alternator (bad bearings)
So I cleared the codes I was getting for the knock sensor and I figured the car is code free.... that wasnt the case for too long
I got the check engine light. I connected a OBD 2 generic scanner and it showed the car has NO codes but the MIL indicator on the scanner turned on.. telling me that the MIL is ON. No shi% ... I could figure that one out by looking at the dash. ($100 well spent on the scanner )
SO I pulled the computer on the side and got codes
33 and 35
33 is the front left O2 sensor and
35 is the EGR temp sensor.
Funny the OBD reader didn't pick that up. Are these codes related? Would one cause the other to tigger?
Any thoughts
