[s3] »
https://forums.nicoclub.com/-u-u9889.html
Sat Mar 06, 2004 7:22 pm
8k is fine, but here are some things you will be looking forward to.
1) Turbos will die soon, at around 100k mileage the stock turbos will start its journey to death. ($2000+ for a stock set) better off going with upgraded turbos (JWT Sport 500s ~$1700) + labor to install.
2) A/C will need retrofit, unless you do the Freeze12 stuff or R134A retrofit, or stick with R12 Coolant ($hundreds per pound)
3) More than likely you will mod the Z to stage 3, the most common stage. Plan on spending ~$2000 or so to get to stage 3.
4) The stock spoiler will most likely fall apart sooner or later, I think its foam and starts to rust from underneath where it is attached to the hatch.
5) Antenna is optional since you will be getting rid of the Bose system. There are 2 antenna's in the Z, the most obvious one that goes up and down and the defroster lines on the hatch window. The Bose system switches between the 2 for the best signal possible. Aftermarket units can use both with a simple mod. More than likely the Bose speakers will blow ... soon.
6) Check for signs of safety boost, if the car only boosts to 7PSI it needs some maintainence (detonation sensor, or a host of other things) Det. sensor - $600-$1000 in parts/labor.
Thats all I can think about for now, $8k for this car is very good considering I see no signs of abuse. I would test drive it to make sure it boosts to +14 on the stock gauge.
