MaxDoc »
https://forums.nicoclub.com/maxdoc-u32203.html
Fri Sep 02, 2005 11:28 am
Here are some pics of my son's and my "winter" project that just hit the streets this past Saturday.
Here is what we did over the LONG "winter"
Motor: * Redtop S13 SR20DET * Blitz FMIC kit (23"x10"x2") * 3" Stainless exhaust (3" downpipe, test pipe, and HKS 25th anniversary cat-back) * KOYO 2-core racing radiator * dual FAL 12" fans * Greddy Catch can
Drivetrain: * Tein HE coilovers * Front/Rear strut tower bars * BuddyClub P1 wheels (16x7.5 front and 16x8.5 rear) * Mickey Thompson 26x10.5" drag radials * Whiteline polyurethane bushing kit * 180sx VLSD * LS Auto Chromemoly 4340 axles * SPEC Stage 3 (6 puck clutch) * Fidanza lightened flywheel * Driveshaft Safety loop
Intake/Fuel: * Greddy intake manifold * Custom top feed fuel rail w/ -8 fuel fittings * MSD top feed 96/lb injectors * Twin Walbro 255lph fuel pumps * Aeromotive FPR * AEM EMS * Splitfire DIS coilpack kit * -8 Stainless braided teflon fuel feed line * -6 Stainless braided teflon fuel return line
Turbo/Manifold: * Precision PT67 turbo (T4)...polished the housing to look like old Turbonetics turbo. * Sublime Speed Tech 4" intake pipe w/ K&N filter * Sublime Speed Tech Top-mount Stainless steel exhaust manifold * Tial 40mm wastegare with 1.0 bar spring * Tial racing blow-off valve
Built Motor Specs: * Block has been cleaned, decked, and balanced * bored 40 over and powerhoned * crankshaft has been micropolished * Wiseco pistons (9.0:1) * Eagle rods * ARP Head/Main studs, fasteners, etc. * Power Enterprises 1.5mm metal headgasket * Ferrea double-valve springs,titanium retainers, seats * Tomei Rocker Arm Stoppers * HKS 272 Step 2 cams * HKS Adj. cam sprockets * Comp. 5-angle valve job w/ radius entry
MaxDoc
