Midway Nissan's July special
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
Henry G
Is it possible to get the SR20 valve cover acorn bolts?
VinceSez
Car: 1992 Nissan 240sx
how much for a new timing chain kit for a 92 240sx fastback?
onosqv
Car: '92 240sx Vert
part #'s please:Fuel pump o-ring? Fuel pump sock?
**EDIT: also part #'s for oil pan bolts
for 89 240sx. It's the ring you need to replace when you replace the fuel pump. I "think" you need to replace the sock too, I'm not positive.
Thanks!
MidwayParts
Vendor
Car: 2011 Titan
Henry G wrote: Is it possible to get the SR20 valve cover acorn bolts?
The acorn nuts are number 01217-00221 and the valve cover stud they go on are 13508-53J10
MidwayParts
Vendor
Car: 2011 Titan
VinceSez wrote:how much for a new timing chain kit for a 92 240sx fastback?
Nissan doesnt make a kit but I can get you a quote of the peices you need. Do you have the 2.4E or the 2.4D?
MidwayParts
Vendor
Car: 2011 Titan
brokeAs240sx wrote:part #'s please:Fuel pump o-ring? Fuel pump sock?
Thanks!
The filter is number 17275-51E00 and the seal is 17342-01A00. You can do a number search for those here: http://www.trademotion.com/par...gid=0
Henry G
Thanks again Dan! Got the Nismo mounts today. Good stuff!
MidwayParts
Vendor
Car: 2011 Titan
Henry G wrote: Thanks again Dan! Got the Nismo mounts today. Good stuff!
180fan
Car: 89 fastback
Hey Dan any way I can order just the drivers side kouki tail light and the black colored finishing panel for the s13 fastback kouki's?
zer0c123
Car: 1993 Nissan 240SX Hatch
My 93 240sx never came with a front lip. If i order the front lip spoiler for the 91-94 240sx does it come with all the screws and brackets to install it?
tractorcrusher
Car: 1993 240SX Coupe
Hey dantech,
Can you help me find the Exhaust Manifold Shield for my 1993 240SX? I can't find it on your site.
Also need a power antenna shaft.
Thanks!
Shift_Tommy
Car: Nissan 240sx
hey dan how much for knock sensor for 93 240sx fb
MidwayParts
Vendor
Car: 2011 Titan
zer0c123 wrote:My 93 240sx never came with a front lip. If i order the front lip spoiler for the 91-94 240sx does it come with all the screws and brackets to install it?
If you order number K6010-51F25 then you'll get a kit that comes with the brackets. Heres a pic.
MidwayParts
Vendor
Car: 2011 Titan
tractorcrusher wrote:Hey dantech,
Thanks!
The number for the shield is 16590-53F00 and the antenna rod and cable is 28215-50J06. You can do a factory Nissan number search for those here: http://www.trademotion.com/par...14024
MidwayParts
Vendor
Car: 2011 Titan
Shift_Tommy wrote:hey dan how much for knock sensor for 93 240sx fb
You can find that here: http://www.trademotion.com/par...gid=1
tractorcrusher
Great, thank you. Before I order, I have one more question: Do you have replacement shift boots?
MidwayParts
Vendor
Car: 2011 Titan
180fan wrote:Hey Dan any way I can order just the drivers side kouki tail light and the black colored finishing panel for the s13 fastback kouki's?
I'll check but I think you'll need to order a whole kit for that. I'll get back to you.
MidwayParts
Vendor
Car: 2011 Titan
Yes. The one for your car is here: http://www.trademotion.com/par...gid=2
tractorcrusher
Just placed my order. Thanks!
180fan
Car: 89 fastback
Thanks Dan. Hopefully you'll be able to get those two parts seperately so I can get on the repairs to the back of my car (caused by my buddy's car)
MidwayParts
Vendor
Car: 2011 Titan
tractorcrusher wrote:Just placed my order. Thanks!
Got it. Thanks a bunch
Asia989
Car: 90 s13.4
hey dan how much for a digital speedometer shipped to 33510?
zer0c123
Thanks for answering my question on the front lip.
I am also looking for the following parts for my 93 240sx 5sp
1. Looking for one end of harness connector that connects to the TPS connector. The ground wire got snapped off and there isn't enough slack left to tape it up
I traced the plugs wires through the taped mixed wires above the fuel injectors.I got a part # from the sticker on the taped up wires 24011-53F00, but i'm not sure if this is what i'm looking for.
2. I think it is called a lower shift boot ( see pic on the bottom). I searched the part # from the pic, but nothing came up.
3. Manual transmission magnetic drain plug and the one for the differential.
MidwayParts
Vendor
Car: 2011 Titan
Asia989 wrote:hey dan how much for a digital speedometer shipped to 33510?
fer what?
MidwayParts
Vendor
Car: 2011 Titan
zer0c123 wrote:Thanks for answering my question on the front lip.
1. Im unable to get you just the connector for that sensor. The number you came across is the number that I could get for you but its the entire harness and its about $300.
2. That number in the picture is correct. Try doing that search here: http://www.trademotion.com/par...14024
3. The trans plug is 32103-U8400 and the diff plug is 32103-U8401. You can do that factory number search at that other link also.
180fan
Car: 89 fastback
Hey Dan, any word on that 180sx kouki lens? Also any idea when the harness is going to ship?
Asia989
Car: 90 s13.4
dantech wrote:
fer what?
91 coupe, jus the instrument cluster
MidwayParts
Vendor
Car: 2011 Titan
180fan wrote:Hey Dan, any word on that 180sx kouki lens? Also any idea when the harness is going to ship?
Whats your order number? I'll check it out.
MidwayParts
Vendor
Car: 2011 Titan
Its part number 24821-54F80 and is $161.24. Shipping would be about $15. You can do a number search for that here: http://www.trademotion.com/par...14024
180fan
Car: 89 fastback
Return to “Advertisers' Marketplace!”
