The rear for the 300Z are part number 43222-50J00brokeAs240sx wrote:
Thanks a lot. I'm thinking of the 60mm one. But I would also like the part # of the OEM studs (depends on which set of wheels I'll be getting in the next week or so). I tried looking on different web sites & just got confused w/ all the different part #'s for all the studs. I'll leave it to the expert to tell me which one is right .
Thanks again!
That was another thing I was wondering about. All I know is that my rear hub is from a 92 NA 300zx. I will be putting on an 89 240sx. Hope that helps?dantech wrote:The rear for the 300Z are part number 43222-50J00
The fronts for the 240SX are 43222-35F00
The Nismo ones list for "solid rear axle" and "without solid rear axle". Do you know which of those you would need?
Sorry if I was unclear.dantech wrote:Are you changing the front or the back?
Are those the oem part #'s?dantech wrote:The rear for the 300Z are part number 43222-50J00
Those part numbers I gave you are the factory number for the two applications. The Nismo bolts are 10 studs per kit and are $52.20. The catalog mentions that they only fit the fronts on the 240 and the 300. Id go with the non solid rear axle application which is Nismo number 40222-RS045.brokeAs240sx wrote:
I have the following:
Front: Attain/GTO hub (told it has same thread/knurl as oem 240sx, except they are 5 lug)Rear: 300zx 92 N/A
I plan on changing out all my studs to the longer 60mm version. In the worse case, I will just do the rear 300zx oem studs.
Thanks again for all your help.
I think the one your looking for is this highlighted one. Its about $34 and is part number 20712-19V00. You can do a number search for that here: http://www.trademotion.com/par...gid=0kane2g wrote:hey dan, I need a piece that goes between a trans mount and a downpipe.L shaped.Can you bring up a pic?Oh its a 92 240sx manual
Okay, Ive got those bushings listed on my catalogs by the OEM number now. Thanks.180fan wrote:Hey Dan, can't get those Nismo bushing part numbers to work on the website. I'll be calling in a few days to place my order, but wanted to bring that to your attention for now.
Thanks a lot, great price on those. And just to be absolutely sure before placing my order, when you said "and the 300", you meant the 300 rear yes?dantech wrote:Those part numbers I gave you are the factory number for the two applications. The Nismo bolts are 10 studs per kit and are $52.20. The catalog mentions that they only fit the fronts on the 240 and the 300. Id go with the non solid rear axle application which is Nismo number 40222-RS045.
20621 is the one I need.dantech wrote:I think the one your looking for is this highlighted one. http://www.trademotion.com/par...gid=0
Thats a part number 20610-52F00 and you can do a number search at the same link. Thankskane2g wrote:20621 is the one I need.
nab911 wrote:Dan i placed my order but never heard anything about it. I got the auto transmission pan for the 240sx.. any idea? Email: [email protected]
Here is a link to those mounts:http://www.trademotion.com/par...gid=1SlideAddictionRPS13 wrote:Dantech how much for motor mounts for 89 fastback shipped to 91766 CA?
Its like $12 or $14 each kit. Im not sure about the dimensions of the box they are gonna come in but I can speculate on that shipping.180fan wrote:Dan, how much for shipping on 4 of those power braces for s13 to zip code 94121? I'm getting local guys in on a buy now. lol
kane2g wrote:Thanks Dan, just got my 02 and the hats
As always, great deals.Too bad I'm so broke, but I will be getting the braces sooner or later.
The time will depend on two things: 1. When you order them and 2. When Nissan Motosports ships them to me. If you put the order in today, I'll call Motorsports and get them ordered. Yesterday, Motorsports told me they are short handed right now and shipping from them has been taking a week and a half. Then once I get them, Id probably be two or three days to you. As I see it total, about two weeks.180fan wrote:Hey Dan, how soon will you be getting them in? I need 4 and still need to know the shipping on them total.
thanks again man
Here is where you will find the hubs listed:http://www.trademotion.com/par...gid=1kouki-gymkhana wrote:Hey Dan, I need some serious help here! I'm trying to swap to 5 lug front hubs from an s14 non-abs 240sx (95-98). I tried searching your site but couldn't find what I need. Here are the parts I need. Can you give me the part numbers/ a price quote for each?
1 front 5 lug s14 SE hub (non-abs)
2 front hub locking nuts and washers and pins (all the parts that secure the hub to the spindle) for a 95 240sx SE
2 sets of front spindle bolts (the hardware that ties into the LCA, tension rod, etc.) for a 95 240sx SE
Both front tension rod bushings for an s13 240sx SE 1993 non-abs.
Thanks!
Well looks like my online catalogs have a pretty good pic of the handle. Let me know if you need a more descriptive pic. Thanks and here you go:http://www.trademotion.com/par...gid=2NateDogg wrote:Hi,
Looking for the sunroof latch assembly for a '91 240sx with the manual sunroof and HICAS.
Please post a diagram so I can see what I need.
Thanks,Nate
Its about $8 and its part number 12309-29S00.bassman31386 wrote:how much for a 1991 dohc crank pulley bolt shipped to 35643? thanks
