You can go online and type in those numbers and place the order that way. Then you can keep tabs on the status of the order. Or you can call me at 1-800-321-6926 and I'll get you handled.Jeff240sx wrote:
Great, how do I order?-Jeff
Ditto from the last question. Just mention the whole envelope deal in the comment area of the order. I get all of the orders anyhoo.Neejay wrote:
Thanks Dan! How do you want me to go about ordering?
Neejay wrote:Order ID: 12660944
Thanks Dan.
Heres a quote with all of the part numbers you need. Just go here: http://www.trademotion.com/par...14024 and do a search for all of them. Hope this helps.Siizzzoooo wrote:Dan, ok...lol sorry this is exactly what I need now!
I need the hydraulic line like the one in this picture at the bottom of the page. labeled: 30650
the only thing is, I need it for a 93 240sx Coupe, not a 95-96. Is it the same part?
I also need pressure plate bolts for a 97 240sx-however many I need.
I also need the following01121-06871 qty4
01121-06881 qty1
01121-06901 qty1
31377-15U00 qty1
let me know ASAP, I'm gonna need these early next week!
Glad I can help. Thanks for the buisness.Neejay wrote:Thanks a lot Dan! I got the shipping refund.
Customer service like this is what keeps the business going
fer what?dvd wrote:hey dan, do you have the part number for the pins that hold down the axle bolts in the rear? thanks.
cotter pin i think. thanks.
for the rear axle bolt.dantech wrote:fer what?
Im sorry. I meant what kind of car.dvd wrote:r
Its a part number 00921-5402A and it does look like a cotter pin.dvd wrote:ooh ok 89 240sx
They are part number 12293-40F00 and you can do a search for those here: http://www.trademotion.com/par...14024bassman31386 wrote:I need a complete set of oem main bolts (the bolts that hold the crank to the block) for my 93 240sx. thanks
Last month I started stocking those and have at least two in stock at all times now (unless its on backorder at the time). I have plenty right now.zer0c123 wrote:What's the turn around time if I place an order for nismo motor and transmission mounts?
93 240sx DOHC 5sp
If i remember correctly from dissassembling my block, there are two different types of bolts that hold the crank to the block. I'm pretty sure that one is shorter than the other.dantech wrote:They are part number 12293-40F00 and you can do a search for those here: http://www.trademotion.com/par...14024
I'll ship you out another today. Sorry bout the mix up.Neejay wrote:Got a problem Dan!
I was only sent 1 bolt, so I double checked my order on your site, and sure enough it had "Qty = 2". I also tried my best to search the box/envelope in case I overlooked it, didnt see the other one though.
Order: 12660944
I sure hope so. Hope he's ok and nothing bad happened... not like Dan to be offline for so long. And is it just me, or is the site not working either? I need partssss.ralphdig wrote:Is Dan on vacation or what?
You can access catalogs here: http://www.trademotion.com/par...gid=0brokeAs240sx wrote:
