Midway GMC / Pontiac / Buick ?????
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
MidwayParts
Vendor
Car: 2011 Titan
Hi everyone. Im glad to annouce that we are now a carrier for the GMC,Pontiac and Buick lines. As some of you might know, I am a full supplier of the GM line and now we have all of these car lines available as online catalogs. If you ever have any need for any GM parts, I'll be glad to assist you with either finding the part in these catalogs, or getting you a factory part number so you can search yourself. Thanks for all the buisness and I hope to here from you all soon.
180fan
Car: 89 fastback
*ahem* I think it might be appropriate for me to make the first pricing request. I need the following parts quoted...
1252-0756 and 1252-0757
it's for a 95 pontiac firebird, 3.4L V6 with ATvin - 2g2fs22sxs2227698
Gotta keep the parts train movin man.
MidwayParts
Vendor
Car: 2011 Titan
180fan wrote:*ahem* I think it might be appropriate for me to make the first pricing request. I need the following parts quoted...
I just typed those numbers into the multiple factory number search and heres what I got. You dont even need to use the "dashs". Hope this helps.
180fan
Car: 89 fastback
Hmm, looks like I found the wrong part numbers. Can you help me find the part numbers for the intake manifold gasket kit and the headgasket set for the firebird with the info above?
MidwayParts
Vendor
Car: 2011 Titan
180fan wrote:Hmm, looks like I found the wrong part numbers. Can you help me find the part numbers for the intake manifold gasket kit and the headgasket set for the firebird with the info above?
The intake gaskets can be found here: http://www.trademotion.com/par...gid=1And the head gasket can be found here: http://www.trademotion.com/par...gid=1There are the two kits also. The intake comes as a set upper and lower and is part number 12520756 and the head also comes as a set which is number 12520757. You had the numbers of the kits correct.
180fan
Car: 89 fastback
whoa so those are the part numbers for the headgasket and intake manifold setup for the 3.4L v6 1995 firebird? I guess you'll be seeing an order for those shortly.
MidwayParts
Vendor
Car: 2011 Titan
180fan wrote:whoa so those are the part numbers for the headgasket and intake manifold setup for the 3.4L v6 1995 firebird? I guess you'll be seeing an order for those shortly.
Return to “Advertisers' Marketplace!”
