Cajun »
https://forums.nicoclub.com/cajun-u273932.html
Sat Apr 29, 2017 12:38 pm
Hi everyone new to the forums. Looking for help with a issue.
02 Altima 3.5L
120k miles
No check engine light or codes.
Had this problem before the tune up but didn't pay it much mind.
Changed alternator, new plugs, coils, rear valve cover, intake manifold gasket, intake collector gasket, changed microfilters orings pintle caps on injectors, and changed all the gaskets on the collector to throttle body. Preformed the throttle relearn procedure on 2 off 10. The on off pedal 5x hold till flash and steady start Rev 3 times.
Car idles at 750rpm runs great except between 3750 to 4750rpm it feels like a misfire or something. Like the throttle open close. A hiccup or something. After 4750rpm it will open up and run. Came here to see what the experts thought. I feel it has to do something with the electric throttle body. What do yall think? What should I do?
Any help is greatly appreciated! Thanks!
