nuclearcarnie wrote:Not a big fan of the juice. Had it on cars and on a bike. Can't argue the bang for the buck but I hate having to fill the bottles. I also hate the all on or all off with nitrous, even with a progressive system. Low psi turbo is what I am going to do. It is only the first step, I have many plans for the car.
Whats up kids, nobody has info about the midwest?
Understand that. Just wanted to make sure you knew there are other options for getting more air in the motor.
On the Hemi turbo and SC systems were not huge gains due to fuel managment issues the engine computer is impossible to hack and all the piggyback controllers have unintended side effects since a bunch of things were partially controled by map sensor voltage.
The on off effect is huge even once your already moving but an extra 150 hp is pretty hard to miss! There were a couple guys running 3 kits with progressive controllers that pulse the solenoids before opening them wide. Have the controler time the shots was nice too. A stock Hemi motor is safe up to 200 hp shot with a spark plug change. I've seen forged strokers with a lot more nitrous.
I'm interested to see your gains on a stock motor. I agree with you on the low psi turbo. If you do break something then you can go forged bottom end, lower the compression and turn up the boost!
Have you checked out
http://www.alteredatmosphere.com ?
If they can't help you maybe they can point you in the right direction?
Jeff
