Like I said earlier, AEM will be releasing a plug and play for the SR that uses the OEM harness. THey are working on the calibration right now.My engine came with a cut harness (cut at firewall) so i has all the plugs that plug into the OEM sensors, and all my aftermarket sensors came with their own plugs. I basically built the wiring harness from the sensors to the EMS. The EMS does not come with any wiring, it was made to plug directly into an EVO 8 factory OEM harness (which is a standard OBD style plug). Since I dont have an EVO 8, I got my hands on some new OBD style plugs and some pins. Basically I just pinned out the harness and installed the pins into the EMS plugs. (Dont try this unless you have the correct crimping tool, otherwise it is a major pain in the arse).
For cam/crank signal, I used the factory S13 cam sensor. At the time AEM did not think that their EMS would work with the 360-window disc (its an optical sensor) that was in the sensor. So I designed a new disc & had it laser cut out of stainless steel. It had 24 outer windows and 1 inner window, the 24 are for the cam, the one is for the crank signal.BUT... AEM has very recently made the stock 360 window disc work with their latest software, so that step is totally unecessary.
I have maps that I use on the car currently, it runs great, nice and rich for now, no stalling, no backfires, perfect idle. It is waiting to go to a professional AEM EMS tuner to finish off the details and really get it dialed exactly how I want it. So I really dont think the maps are worth sharing at this point.The link below goes to a thread that has an ignition map for the SR. About midway down, Enthalpy posts what he is running for timing at 0 manifold pressure, from there you retard timing .75 degrees for every 1 psi of boost.
http://forums.freshalloy.com/u...art=1
I used his instructions and built a timing map almost exactly to what he is running. Needless to say, i am very pleased with it. I am getting no signs of knock, backfire or anything, just breakneck acceleration. I suggest following his lead also, be sure to read the whole post.
Heres a brief rundown of what I am using for sensor/actuators:-stock SR TPS-Stock Cam/Crank sensor with custom disc-3.5 bar AEM MAP sensor-GM intake air temp sensor- Stock SR knock sensor-Stock SR injectors-AEM wideband oxygen sensor-AEM EGT sensor-AEM fuel pressure sensor-GM Cyclone boost control solenoid (controlled by AEM EMS)-stock SR water temp sensor-AEM capacitor discharge ignition, stock SR coils.
and thats it. Not much is required to make an engine run, just he bare essentials.Let me know if you want anything else.
