fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Mon Feb 14, 2005 7:59 pm
nitromethane (CH3NO2) works very much the same as regular nitrous oxide would. When it combusts within the cyl it donates free oxygen which can then be used to aid even more combustion. Because of this though, nitromethane use also results in higher temperatures within the engine... Unlike methanol which is used (among other things) to cool the charge
I was looking at using nitromethane also WD.. I kept falling over it every time I did searches to find sources for pure methanol and it definetly got me thinking. Youre right that it cant be simply added to a gas tank (because of its corrosive qualities, which is emphesised by the fact that fuel remains in the tank for semi-extended periods of time), but it can be mixed in with methanol (or just water) as another form of staged alochol injection.
Still, nitromethane is really really expensive. Prices I have found generally hover around $30-$50 for a single gallon, $350 for 15 gallons, or $795 for the hardcore 53 gallon drum. While it really does seem like a cool idea, its just not very cost effective when you compare it to regular methanol or even regular gas nitrous oxide.
