Methanol Injection
bslyth
Car: 1995 Nissan Hardbody VG30E
1996 Nissan 240sx SR20DET
I'm probably going to get a methanol injection system set up when the cold at intake goes in. Have any y33 modders tried this? If so, what can I expect in gains and what concentrations should I aim for?
94Q45Beast
Car: 1994 INFINITI Q45t w/HICAS
1992 INFINITI Q45
2017 INFINITI Q70S AWD BLACK ON BLACK
I'm doing the exact same thing on a G50, currently doing the physics part of it.
bslyth
Would you be able to help me out when you get it to work out? Even equations and topics to research will help, not asking you to do all the work
94Q45Beast
1992 INFINITI Q45
its a slow job for me, its something i'm doing in my free time which I don't get as much.
Brew Q
Car: '92 Q45 91k miles, '05 FX35
past: '99 740i (r.i.p.), '92 Maxima SE, '89 Maxima SE, '04 FX35
On an N/A motor I wouldn't even bother with meth - your intake isn't getting hot enough to see much benefit. A budget (DIY installed) turbo set up will yield some serious power on the VH (then you install a meth kit). That is where I'd go first and I wouldn't even waste my time with anything else. An ebay GT45, and a lot of plumbing and welding. It is well worth it though.
bslyth
Awesome info; I was hoping to get some fun with the meth before a turbo. Turbo is on the install list too, but I haven't the money or time at the moment.
Do all GT45 turbos come the same, or should I seek a specific A/R and size?
Brew Q
http://www.ebay.com/itm/BRAND-NEW-HIGH- ... 460b34735f
that's the one you want and from the seller you want to deal with. They sell a ton of those and they are known to be of high quality.
Learn to weld if you don't already know how. You could save some money and do all the welding yourself.
bslyth
So another question now.
I noticed those don't have wastegates. Should I worry about fashioning a wastegate/buying an external wastegate, or is it not that big of a deal.
From what I recall 7psi is the absolute max recommended without changing anything in the engine, and I likely would do 5 psi max.
