Recently I noticed when ever the car drive out of the drive way or over bump/pot hole, it make a metallic thump sound on the passenger side. I've researched the symptom and it turns out to be a bad strut mount and bearing. I took both front wheels off and all the rubbers, bushings are fine. Also I tried to wiggle from up to bottom, left to right and no play at all, very solid. Oh and it also klunk too.
My questions are: if i'm replacing the mount/bearing myself do, do I need to change both the driver and the passenger mount/bearings too? and which companies do you recommend? since I've heard that the factory strut/mount isn't good.
My car is 07 at currently at 44,000 mile.
Thanks for your input.
