MattB wrote:It's definitely not a clicking sound. It's not quite a grinding sound either...it really sounds most like rubbing, as if something is slighly out of position. If the bearings were going bad, wouldn't the noise occur when turning either direction?
The 2nd paragraph in my earlier response answered your last question.
So problem is now most likely with the front brake system, though other possibilities exist. Remove the wheel and make a thorough inspection of the pads (2mm minimum thickness, anything less will trigger pad warning), rotor (24mm min. thickness), the shims, pad return lever, caliper, etc. If you have a dial gauge and stand, measure the runout - 0.07mm max (or 2.8 mils max), with lugnuts installed. A warped or very thin rotor may become wobbly, generating such noise during turns and even during straight line driving.
