According to SCC:
I'm not sure I'm picturing this correctly, but if I am, then rubber is the way to go, right? And if thats true then why are metal stems recommended other than for looks and profit? Or is rubber not as durable as the metal ones?SCC wrote:When we installed them, we found a few surprises. We had a new set of Bridgestone RE070s (the stock tire) shipped from the Tire Rack, and had them mounted at Shoreline Motoring in Huntington Beach, Calif. Luckily for us, Shoreline is run by longtime SCC contributor Dan Barnes, one of the most anal tech geeks we've ever met. He immediately told us to throw away the pretty metal valve stems that came with the wheels. The valve stems are secured to the wheel with two nuts (one to tighten, the other to jam the first in place) on the inside of the wheel. Problem is, the nuts stick out right on the part of the wheel the bead has to slide on when it's mounted. This makes the tires difficult to mount and risks damaging the tire bead, the valve stem, or both. Without Locktite, there's also a chance the nuts can back off inside the tire. You'll never know until the valve stem shoots out of the wheel like a dart from a blowgun. Most metal valve stems install from the inside and have the nut on the outside. If the nut backs off, air pressure is still holding the valve stem in place. We simply switched to cheap, rubber stems.
Also, is either one not allowed or prefered for sanctioned racing?
