metal shavings in oil pan
Justin35ll
Car: s13 coupe sr20det
This looks almost like the same thing as SxMachine's metal shavings in his oil pan.
My sr has a knock. Does this look anything like main, or rod bearing shavings?It does look kinda look copper I don't know what the oem bearings are made from.
SxMachine
Car: Im on a horse
Yea homie we got the same issues, cept i got no knock. Yours sounds a bit more serious. No standard bearings 4 you unless u gauge em. Ima be pullin my motor prob this weekend. I wouldve turboed the ka if i knew this would hap.
angela
most likely there the rod bearings..correct me if im wrong but copper is the last layer or close to the last layer of the bearing.. i had the same problem and yup it was my number 3 rod bearing..good luck
Justin35ll
Yeah I tore it down, it was a number 3 rod bearing. Gonna bring the crank somewhere tomorrow and see if it's still useableIf it is I'll probably repolish get some new bearings, pistons, and rods and maybe do a little build
