andrewdees »
https://forums.nicoclub.com/andrewdees-u5707.html
Wed May 17, 2006 5:14 am
Hey guys, On sunday I put a blacktop SR in and got it running just fine. But before I put it in, I changed the sealant on the oil pan since it was leaking. I found 3 very small bronze color metal pieces that when pieced together looked like a half circle. My turbo does have a lot of front to back movement on the compressor turbine. Is it possible for the center bearing to fall apart and maybe run down the turbo drain tube into the oil pan? thanks
-Drew
