GreenQ45a »
https://forums.nicoclub.com/greenq45a-u15134.html
Sat Jul 02, 2005 6:25 pm
I noticed while removing the radiator the plastic hose outlets for the upper hose is cracking around the lip..
I will be replacing the following parts before teh Q45a hits the road:
Water pump (need)
Radiator (need)
Active computer(have)
Alternator (have)
Was thinking of doing the PAN DROP while im under there doing the Alternator..but I'm unsure if I need a ton of special equipment to do it.
Where should I get the radiator?most of the links to our sponsers are a cookie cutter parts system that all search the same data bases and give the same price..
Metal or another plastic... The metal one is only around 50.00 more than the plastic.
Tomorrow I pull the A\C compressor
