brummy »
https://forums.nicoclub.com/brummy-u213969.html
Mon Jan 07, 2013 10:01 pm
It turned out that cleaning the crankshaft sensor did not fix the P1320 code. It came back after running it for about 25 miles. It seems to trigger when doing a start with a hot engine. It began running rough about 30 seconds after start and the check eng light began to flash shortly after. This time the "cyl 5 misfire" code (P0305 I think) accompanied it...swapped coil packs 3 and 5 and the problem followed. Replaced coil pack and it has been running fine since. A friend of mine says that once one goes, the rest are to follow and I should get another pack on order. Have any of you experienced the same?
As for the metal on the sensor, I changed the oil and did not find metal in the drained oil...cut the filter open and noted a couple very small flakes of metal and some dirt only. Also rechecked the sensor and it didn't pick up any more after 40 miles. Thanks for the ideas about the magnetic drain plug, hard drive magnets and especially the handling warning. I'll give it a try and keep an eye on it...hopefully it's nothing serious...
-jb
