metal noise
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
I have a strange metal noise coming from my car... everytime i hit 1900 rpms to around 2100 rpms... It doesnt matter if it is at wot or just cruising at that rpm... it is getting really annoying... but its definately from the motor somewhere.. any guesses?
SpeedRacer1
Car: 1990 240SX, G35
Something is loose and is resonating at that RPM. There is a very good chance that it is a loose bolt somewhere in the exhaust area. Though it may just be some loose metal somewhere else touching. Does it make the noise in neutral?
Yes, doesnt matter when... but if the motor is spinning at that rpm then it makes the noise... havent noticed it anywhere else though. It is just pissing me off. LOL After i got my radio stolen last week I have noticed it a lot more!
180sxmonster
Car: 180sx
check all of your metal gasket, especially the one where your turbo mounts up to the manifold..... i had the same problem and then when i replaced my stock manifold with the equal length one ive notice that the gasket between the two had cracked and cause exhaust leak..... it was rattling like crazy or rattling.... it was annoying... hope that helps
itsnever2fast
Car: 1990 S13 HATCH SR20DET REDTOP
pop the hood and hold the throttle cable till stuff starts rattling then narrow it down to were it is coming from.
adrianfromthecastle
Car: 1992 Nissan 240sx
are you possitive its coming from the motor? not from transmission?
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Sounds like a loose heat shield
I was thinkign flywheel... but that doesnt seem possible. I dont have a heatshield either
da40
Car: 1995 SE 240sx
might be ur turbo hmmmmmmm check for shaft play might be time for a rebuild
