metal hg thickness
minivan_don
ok ... im trying to figure out what tickness of metal hg to get for my s2 rb25 and although i have searched here and on hybridz, i have not found any difinitve answers.
what i got? - wiseco 8.4:1 pistons- eagle rb rods
im just gathering some quotes for the machinging i require ... (boring/honing/decking/hot tank block + resurface head) and from searching around i found a 1mm and 1.29mm greddy hg
http://www.jgycustoms.com/RB20DETparts.htm
http://www.enjukuracing.com
how can i figure out which gasket will yield me an ideal final compression ratio ?? say 8.6:1 - 8.8:1
Modified by minivan_don at 7:03 PM 1/24/2007
Modified by minivan_don at 7:04 PM 1/24/2007
Joe
it depends how much is taken off the block and head. you are going to have to deck it pretty far to get a .2 bump in static compression even with a 1mm gasket
have the machine shop do the measurements on the block and head or get a graduated cylinder and some plexiglass and do it yourself.
http://www.valvoline.com/carca...701cr
minivan_don
i doesnt have to be spot on 8.6-8.8:1 ... if i could a bit higher than 8.4:1 is preferred.
thanks for the recommendation ... thats what i figured in a worst case scenaro but my buddy and i are building a huge order with an online store and i can get the hg at a discount and no shipping so thats why im trying to figure this out now
freepunk
Found this thread pretty informational with hg thickness.
zerothread?id=186816
Chaos the Xile
Car: 1974 Datsun 260Z
Well What about Metal H/G With the stock thickness so you don't ahve to shave off of the block? Where can those be bought or are they the same as the 1mm?
Joe
IMO you MUST deck the head and block with going to a MHG.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
IMO too.
minivan_don
both the head and block WILL be machined ... thats is not in debate here ..
enjukuracing.com sell a 1mm greddy metal hg
Chaos the Xile
ok thats all i wondered.
