im with him i have a cometic and have no problems with it so farDori Dori wrote:Yes, compression would be lowered slightly.
The best aftermarket drop in metal head gasket is the apexi. It's like having your block o-ringed.
Myself and many others run a cometic metal head gasket (which I've heard is a rip off of the Greddy) which is the cheapest HG afaik. Many high hp SR's use that gasket w/ no problems.
Bore is 86mm (as is stroke, FYI).
