metal head gasket
boost_creep
Car: 92 sr powered coupe,06 Spec V
im just planning ahead for the future.my question is,when you install a metal head gasket,do you have to pull the motor and get the block resurfaced.or can u just mill the head?my cuz just did his supra and he had to get the block machined.this is a much longer engine though.if anyone could fill me in,that would be cool.
JJ240
Car: 95 white 240
If the deck is warped or scored then yes you do. If your head isn't warped or scored you dont have to have that machined either.
boost_creep
bump:
boost_creep
sometimes i wonder why i even bother posting in this forum.
c'mon guys!!
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Dude the answer is right above your second post. I have a metal headgasket and I did NOT get my block or head machined. Hell I didnt even clean off the surfaces too good.
boost_creep
thank you sir, i was just lookin for a second opinion.
Nismo_Freak
Car: 89 Nissan 240SX
Better to be safe than lucky.
Especially with aluminum surfaces, I would look to have them both checked.
Even removing the headstuds in the incorrect pattern can add warp to the head.
