metal head gasket for ca18det
Ca18det240sxchk
Car: nissan 240sx swapped ca18det
where can i get a metal head gasket for ca18det?
Darius2250
I called Cometic, and they took my order and my money and sent me one, took about 4 days
nismoplsr
Ca18det240sxchk wrote:where can i get a metal head gasket for ca18det?
There are lots of places. I would not get a Cometic based on everyone elses experience with it.
I just ordered a Greddy/TRUST gasket last week and its on the way to me right now. http://www.rhdjapan.com All together with shipping it cost $210. They also sell Tomei gasket but its $60 more.
Boostboy can supply you with a NISMO one i think.
RedCA18S13
Get a Tomei you can buy them from http://www.180sxfaktory.com i think if not one of them go with Greddy I believe Tomei to be better in my opinion
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
im using a nismo metal hg. its the bomb. i got it from dee.
sideways danny
Car: s13, CA18DET
I use ACL metal gaskets. only available in 1.3mm though
Ca18det240sxchk
ok well one of yall need to hook it up with a nismo or tomei head gasket!! have that person email me [email protected] is my last attempt.. if it doesnt work- im gettin a new CA!
float_6969
REGARDLESS of the Metal HG you pick, you HAVE to have the head AND the block decked. If you don't, it doesn't matter what brand it is, it'll leak.
The cometic works fine for the people getting the head AND block resurface IIRC.
Phyrx
Car: 2001 Audi TT Quattro
I also bought a cometic... hope I didn't make a mistake.
I used an HKS Metal Headgasket on my supra and only had the had resurfaced (After a BHG - typical 7MGTE). I also used ARP studs and everything came out perfectly fine! Does HKS make a metal headgasket for the CA18?
It seems to be the #1 Choice for 7MGTE guys...
fluent
As long as your car hasn't been overheated theirs a 99% chance your block is flat (being iron it is hard to warp/crack) and even the head can also be flat too (i'd check that but!)
float_6969
The block is MUCH less likely to warp, but it's still possible.
boost_boy
Ca18det240sxchk wrote:ok well one of yall need to hook it up with a nismo or tomei head gasket!! have that person email me [email protected] is my last attempt.. if it doesnt work- im gettin a new CA!
I'll give you some professional advice, don't waste your money on a metal headgasket unless you plan on getting pretty stupid with performance mods. A good Felpro gasket should do you just fine for now and there'sno need for headstuds. I would purchase new headbolts as the stockers does get a bit tired and stretch a bit.
Dee
roplusbee
Car: 2007 350Z NISMO
When you say "stupid with performance mods", what do you really mean? I know the magic number is 300 HP, but the CA puts out about 170 HP stock.
boost_boy
roplusbee wrote:When you say "stupid with performance mods", what do you really mean? I know the magic number is 300 HP, but the CA puts out about 170 HP stock.
You can do 300whp on an internally stock CA. When I say stupid performance means sustaining 20+psi runs and so forth and so on.
Dee
roplusbee
Woah. Ok, I feel you. That would be pretty outrageous. Thanks for the clarification.
nismoplsr
roplusbee wrote: That would be pretty outrageous.
Oh it is! This is what i feel i look like driving when full boost hits in a hard run
And i KNOW thats what passengers look like!!! Haha.
I check my head with a straight edge and it was less than 2thou warped if at all. The smallest feeler gauge was a 2thou. When the NISSAN spec limit is 4tho i call it good. Im just going to make sure everything is clean enough to eat off, and also use the copper spray to further seal things up.
Ca18det240sxchk
yes i do want a performance metal head gasket just so i can turn the boost up, Iv been running stock **** the whole time like around 7-8 psi- it suxs!! I was warned not to go over cuz i would blow the head gasket if i started running 14-18psi so yeh...
nismoplsr
Ca18det240sxchk wrote:I was warned not to go over cuz i would blow the head gasket if i started running 14-18psi so yeh...
Was this advice from the shop that says your engine is unrepairable?
boost_boy
Ca18det240sxchk wrote:yes i do want a performance metal head gasket just so i can turn the boost up, Iv been running stock **** the whole time like around 7-8 psi- it suxs!! I was warned not to go over cuz i would blow the head gasket if i started running 14-18psi so yeh...
They got game! You could've run at least 12 psi on the stock system without pissing off the engine. Anyways, I'll email you back and we'll go from there.
Dee
r34 gtr
my head was only about 2 thou out and it leaks like crazy with my nismo gasket. its also been treated with copper spray. have it decked or youll hate yourself later. TRUST me. please god pay the lousy $50 to have the thing milled flat.
Ca18det240sxchk
yeh boost_boy is taking care of the motor- ect im gettn a new motor- so tell his a$$ now-! =) hopefully taking the car down there within the next week...
roplusbee
Woohoo. Make sure you get some pix and stuff so we can follow the progress. See, aren't you glad that you didn't sell me your turbo mani and stuff. Keep us posted hereor in another thread. Good luck...............
