Messed up tension rod?
thefro526
Car: BMW 325Ci & S13 Coupe
I've noticed that one of my wheels is significantly further back in the wheel well that the other. The alignment is not off though just the wheel looks like it's been moved back a few inches. Is this caused by a messed up tension rod? If so should I get a new OEM one or and aftermarket adjustable one. Thanks
Upon further review my LCA looks messed up too. Do you guys thing if I get a new LCA and tension rod it'll fix my problem?
Modified by thefro526 at 3:43 PM 6/10/2008
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
Yeah if suspension components look messed up you really should fix that.It's kinda like walking to the doctor with the bone sticking out your leg, "Doc does this look bad".
you don't want your suspension to fail. Replace the parts, get the car realigned and you should be good.
silnismo
replace your lowwer control arm, DONE!
that would be the only thing causeing your front wheel to be pushed back.
thefro526
Found out that it is the front LCA on the driver's side I can't find one to save my life though . I really need one so that I can drive up to formula d on saturday even though I think I could make it up there with this one. I just don't like driving it like this.
