SloS13 »
https://forums.nicoclub.com/slos13-u1021.html
Sun Apr 11, 2004 5:26 pm
theres a coolant line going into the head. There are 2 sensors about an inch apart. One has 2 wires, then the next has 1 wire. The one that has only 1-wire feeds voltage to your temp gauge. check out this connector, clean it, re-solder it as needed. It'll fix you right up
