Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Mon Apr 07, 2003 10:11 am
Well on the motor, there are two ports for the coolant. The upper outlet port really close to the throttle body. That port is hooked up to the top radiator hose. The other inlet port for coolant is hooked up to the lower hose for the radiator. Sounds to me like you have a thermostat or a air pocket problem. I'd suggest replacing the thermostat and get rid of the air bubble.
